Time Before: 0.00252 seconds
Time After: 0.00305 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00313 seconds
Time After: 0.00356 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00385 seconds
Time After: 0.00400 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00502 seconds
Time After: 0.00743 seconds
Time Taken: 0.00242 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00409 seconds
Time After: 0.01098 seconds
Time Taken: 0.00689 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01388 seconds
Time After: 0.01429 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01736 seconds
Time After: 0.01891 seconds
Time Taken: 0.00155 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01316 seconds
Time After: 0.01916 seconds
Time Taken: 0.00600 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02659 seconds
Time After: 0.02676 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03415 seconds
Time After: 0.03540 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.04639 seconds
Time After: 0.04654 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04880 seconds
Time After: 0.05021 seconds
Time Taken: 0.00140 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106652' WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.06464 seconds
Time After: 0.06494 seconds
Memory Before: 5,998.352 KB
Memory After: 5,998.594 KB
