Time Before: 0.03193 seconds
Time After: 0.04076 seconds
Time Taken: 0.00883 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.04087 seconds
Time After: 0.04133 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.04161 seconds
Time After: 0.04174 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.04249 seconds
Time After: 0.04517 seconds
Time Taken: 0.00268 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.04179 seconds
Time After: 0.04891 seconds
Time Taken: 0.00712 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.05895 seconds
Time After: 0.05936 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.06168 seconds
Time After: 0.06287 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.05817 seconds
Time After: 0.06312 seconds
Time Taken: 0.00495 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.11366 seconds
Time After: 0.11381 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.19026 seconds
Time After: 0.19181 seconds
Time Taken: 0.00155 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.23774 seconds
Time After: 0.23792 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.24645 seconds
Time After: 0.24798 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772800687, location = '/forums/private.php?do=newpm&explain=1&u=106669' WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.27912 seconds
Time After: 0.27937 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
