Time Before: 0.02670 seconds
Time After: 0.03909 seconds
Time Taken: 0.01239 seconds
Time Before: 0.03922 seconds
Time After: 0.03965 seconds
Time Before: 0.03992 seconds
Time After: 0.04005 seconds
Time Before: 0.04093 seconds
Time After: 0.04373 seconds
Time Taken: 0.00280 seconds
Time Before: 0.04014 seconds
Time After: 0.04769 seconds
Time Taken: 0.00755 seconds
Time Before: 0.06181 seconds
Time After: 0.06218 seconds
Time Before: 0.06449 seconds
Time After: 0.06569 seconds
Time Before: 0.06115 seconds
Time After: 0.06590 seconds
Time Taken: 0.00474 seconds
Time Before: 0.10641 seconds
Time After: 0.10654 seconds
Time Before: 0.13383 seconds
Time After: 0.13513 seconds
Time Before: 0.14548 seconds
Time After: 0.14563 seconds
Time Before: 0.14824 seconds
Time After: 0.14972 seconds
UPDATE session SET lastactivity = 1785284753, location = '/forums/private.php?do=newpm&explain=1&u=106717', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.17375 seconds
Time After: 0.17416 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
