Time Before: 0.00944 seconds
Time After: 0.01618 seconds
Time Taken: 0.00674 seconds
Time Before: 0.01627 seconds
Time After: 0.01674 seconds
Time Before: 0.01698 seconds
Time After: 0.01714 seconds
Time Before: 0.01800 seconds
Time After: 0.02031 seconds
Time Taken: 0.00231 seconds
Time Before: 0.01719 seconds
Time After: 0.02463 seconds
Time Taken: 0.00744 seconds
Time Before: 0.03027 seconds
Time After: 0.03064 seconds
Time Before: 0.03309 seconds
Time After: 0.03435 seconds
Time Before: 0.02962 seconds
Time After: 0.03454 seconds
Time Taken: 0.00492 seconds
Time Before: 0.05697 seconds
Time After: 0.05715 seconds
Time Before: 0.07074 seconds
Time After: 0.07204 seconds
Time Before: 0.08041 seconds
Time After: 0.08061 seconds
Time Before: 0.08352 seconds
Time After: 0.08500 seconds
UPDATE session SET lastactivity = 1784733386, location = '/forums/private.php?do=newpm&explain=1&u=106721', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.10435 seconds
Time After: 0.10466 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
