Time Before: 0.01723 seconds
Time After: 0.02255 seconds
Time Taken: 0.00532 seconds
Time Before: 0.02266 seconds
Time After: 0.02311 seconds
Time Before: 0.02334 seconds
Time After: 0.02349 seconds
Time Before: 0.02436 seconds
Time After: 0.02660 seconds
Time Taken: 0.00224 seconds
Time Before: 0.02356 seconds
Time After: 0.03189 seconds
Time Taken: 0.00833 seconds
Time Before: 0.04022 seconds
Time After: 0.04068 seconds
Time Before: 0.04223 seconds
Time After: 0.04352 seconds
Time Before: 0.03939 seconds
Time After: 0.04377 seconds
Time Taken: 0.00437 seconds
Time Before: 0.08136 seconds
Time After: 0.08150 seconds
Time Before: 0.09566 seconds
Time After: 0.09691 seconds
Time Before: 0.10475 seconds
Time After: 0.10492 seconds
Time Before: 0.10794 seconds
Time After: 0.10954 seconds
Time Taken: 0.00160 seconds
UPDATE session SET lastactivity = 1785297661, location = '/forums/private.php?do=newpm&explain=1&u=106749' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12880 seconds
Time After: 0.12911 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
