Time Before: 0.00184 seconds
Time After: 0.00242 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00262 seconds
Time After: 0.00296 seconds
Time Before: 0.00317 seconds
Time After: 0.00328 seconds
Time Before: 0.00413 seconds
Time After: 0.00713 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00333 seconds
Time After: 0.01241 seconds
Time Taken: 0.00908 seconds
Time Before: 0.01481 seconds
Time After: 0.01522 seconds
Time Before: 0.01770 seconds
Time After: 0.01985 seconds
Time Taken: 0.00216 seconds
Time Before: 0.01402 seconds
Time After: 0.02011 seconds
Time Taken: 0.00609 seconds
Time Before: 0.02632 seconds
Time After: 0.02648 seconds
Time Before: 0.02853 seconds
Time After: 0.02983 seconds
End call of global.php: 0.031491041183472
Time Before: 0.03288 seconds
Time After: 0.03324 seconds
Time Before: 0.03519 seconds
Time After: 0.03677 seconds
Time Taken: 0.00158 seconds
SET lastactivity = 1788887735, location = '/forums/private.php?do=newpm&explain=1&u=106750', badlocation = 1
Time Before: 0.05413 seconds
Time After: 0.05444 seconds
Page generated in 0.053220987319946 seconds with 9 queries, spending 0.0097308158874512 doing MySQL queries and 0.043490171432495 doing PHP things.
