Time Before: 0.00163 seconds
Time After: 0.00209 seconds
Time Before: 0.00216 seconds
Time After: 0.00271 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00292 seconds
Time After: 0.00306 seconds
Time Before: 0.00372 seconds
Time After: 0.00612 seconds
Time Taken: 0.00240 seconds
Time Before: 0.00310 seconds
Time After: 0.00954 seconds
Time Taken: 0.00644 seconds
Time Before: 0.01128 seconds
Time After: 0.01162 seconds
Time Before: 0.01430 seconds
Time After: 0.01549 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01065 seconds
Time After: 0.01576 seconds
Time Taken: 0.00511 seconds
Time Before: 0.02232 seconds
Time After: 0.02247 seconds
Time Before: 0.02433 seconds
Time After: 0.02554 seconds
Time Before: 0.02850 seconds
Time After: 0.02867 seconds
Time Before: 0.03152 seconds
Time After: 0.03386 seconds
Time Taken: 0.00234 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106753', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05008 seconds
Time After: 0.05042 seconds
