Time Before: 0.02409 seconds
Time After: 0.03266 seconds
Time Taken: 0.00857 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03277 seconds
Time After: 0.03332 seconds
Time Taken: 0.00055 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03355 seconds
Time After: 0.03367 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03460 seconds
Time After: 0.03723 seconds
Time Taken: 0.00263 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03375 seconds
Time After: 0.04160 seconds
Time Taken: 0.00785 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.04826 seconds
Time After: 0.04873 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.05193 seconds
Time After: 0.05317 seconds
Memory Before: 2,148.789 KB
Memory After: 2,148.648 KB
Time Before: 0.04759 seconds
Time After: 0.05341 seconds
Time Taken: 0.00582 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.672 KB
Time Before: 0.08832 seconds
Time After: 0.08847 seconds
Memory Before: 2,815.242 KB
Memory After: 2,815.758 KB
Time Before: 0.10535 seconds
Time After: 0.10659 seconds
Memory Before: 2,903.539 KB
Memory After: 2,904.133 KB
End call of global.php: 0.1086699962616
Time Before: 0.12116 seconds
Time After: 0.12135 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.12389 seconds
Time After: 0.12531 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=106771'
Time Before: 0.14899 seconds
Time After: 0.14931 seconds
Memory Before: 4,295.492 KB
Memory After: 4,295.734 KB
Page generated in 0.14779710769653 seconds with 9 queries, spending 0.0083153247833252 doing MySQL queries and 0.13948178291321 doing PHP things.
