Time Before: 0.02551 seconds
Time After: 0.03072 seconds
Time Taken: 0.00521 seconds
Time Before: 0.03081 seconds
Time After: 0.03160 seconds
Time Taken: 0.00079 seconds
Time Before: 0.03192 seconds
Time After: 0.03218 seconds
Time Before: 0.03324 seconds
Time After: 0.03652 seconds
Time Taken: 0.00328 seconds
Time Before: 0.03224 seconds
Time After: 0.04107 seconds
Time Taken: 0.00883 seconds
Time Before: 0.04983 seconds
Time After: 0.05026 seconds
Time Before: 0.05282 seconds
Time After: 0.05402 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04917 seconds
Time After: 0.05422 seconds
Time Taken: 0.00505 seconds
Memory After: 2,261.820 KB
Time Before: 0.10150 seconds
Time After: 0.10165 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.11872 seconds
Time After: 0.11994 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.13029 seconds
Time After: 0.13051 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13338 seconds
Time After: 0.13526 seconds
Time Taken: 0.00188 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789121637, location = '/forums/private.php?do=newpm&explain=1&u=106786' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.15432 seconds
Time After: 0.15458 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
