Time Before: 0.00144 seconds
Time After: 0.00194 seconds
Time Before: 0.00202 seconds
Time After: 0.00256 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00282 seconds
Time After: 0.00297 seconds
Time Before: 0.00397 seconds
Time After: 0.00629 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00305 seconds
Time After: 0.01079 seconds
Time Taken: 0.00774 seconds
Time Before: 0.01272 seconds
Time After: 0.01318 seconds
Time Before: 0.01483 seconds
Time After: 0.01608 seconds
Time Before: 0.01199 seconds
Time After: 0.01630 seconds
Time Taken: 0.00430 seconds
Time Before: 0.02263 seconds
Time After: 0.02280 seconds
Time Before: 0.02510 seconds
Time After: 0.02636 seconds
Time Before: 0.02976 seconds
Time After: 0.02993 seconds
Time Before: 0.03266 seconds
Time After: 0.03410 seconds
UPDATE session SET lastactivity = 1789061686, location = '/forums/private.php?do=newpm&explain=1&u=106802' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04800 seconds
Time After: 0.04825 seconds
