Time Before: 0.01603 seconds
Time After: 0.02049 seconds
Time Taken: 0.00446 seconds
Time Before: 0.02060 seconds
Time After: 0.02105 seconds
Time Before: 0.02133 seconds
Time After: 0.02146 seconds
Time Before: 0.02239 seconds
Time After: 0.02501 seconds
Time Taken: 0.00262 seconds
Time Before: 0.02154 seconds
Time After: 0.03039 seconds
Time Taken: 0.00885 seconds
Time Before: 0.03590 seconds
Time After: 0.03633 seconds
Time Before: 0.03896 seconds
Time After: 0.04019 seconds
Time Before: 0.03513 seconds
Time After: 0.04039 seconds
Time Taken: 0.00526 seconds
Time Before: 0.06089 seconds
Time After: 0.06102 seconds
Time Before: 0.07176 seconds
Time After: 0.07306 seconds
Time Before: 0.07930 seconds
Time After: 0.07944 seconds
Time Before: 0.08161 seconds
Time After: 0.08304 seconds
UPDATE session SET lastactivity = 1785408344, location = '/forums/private.php?do=newpm&explain=1&u=10681' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.09892 seconds
Time After: 0.09930 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
