Time Before: 0.02533 seconds
Time After: 0.03357 seconds
Time Taken: 0.00824 seconds
Time Before: 0.03368 seconds
Time After: 0.03414 seconds
Time Before: 0.03437 seconds
Time After: 0.03459 seconds
Time Before: 0.03545 seconds
Time After: 0.03808 seconds
Time Taken: 0.00263 seconds
Time Before: 0.03465 seconds
Time After: 0.04200 seconds
Time Taken: 0.00735 seconds
Time Before: 0.05175 seconds
Time After: 0.05215 seconds
Time Before: 0.05486 seconds
Time After: 0.05605 seconds
Time Before: 0.05104 seconds
Time After: 0.05624 seconds
Time Taken: 0.00520 seconds
Time Before: 0.09564 seconds
Time After: 0.09581 seconds
Time Before: 0.52952 seconds
Time After: 0.53116 seconds
Time Taken: 0.00164 seconds
End call of global.php: 0.53383207321167
Time Before: 0.54452 seconds
Time After: 0.54470 seconds
Time Before: 0.54796 seconds
Time After: 0.54953 seconds
Time Taken: 0.00157 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106826', badlocation = 1
Time Before: 0.56809 seconds
Time After: 0.56835 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.56697392463684 seconds with 9 queries, spending 0.0087146759033203 doing MySQL queries and 0.55825924873352 doing PHP things.
