Time Before: 0.00147 seconds
Time After: 0.00206 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00213 seconds
Time After: 0.00259 seconds
Time Before: 0.00287 seconds
Time After: 0.00301 seconds
Time Before: 0.00392 seconds
Time After: 0.00675 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00309 seconds
Time After: 0.01213 seconds
Time Taken: 0.00904 seconds
Time Before: 0.01442 seconds
Time After: 0.01480 seconds
Time Before: 0.01770 seconds
Time After: 0.01893 seconds
Time Before: 0.01378 seconds
Time After: 0.01918 seconds
Time Taken: 0.00540 seconds
Time Before: 0.02538 seconds
Time After: 0.02552 seconds
Time Before: 0.02753 seconds
Time After: 0.02874 seconds
End call of global.php: 0.030551910400391
Time Before: 0.03183 seconds
Time After: 0.03196 seconds
Time Before: 0.03434 seconds
Time After: 0.03585 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1785372025, location = '/forums/private.php?do=newpm&explain=1&u=106831', badlocation = 1
Time Before: 0.05058 seconds
Time After: 0.05088 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.049582958221436 seconds with 9 queries, spending 0.0083370208740234 doing MySQL queries and 0.041245937347412 doing PHP things.
