Time Before: 0.00145 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00242 seconds
Time Before: 0.00258 seconds
Time After: 0.00269 seconds
Time Before: 0.00337 seconds
Time After: 0.00632 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00273 seconds
Time After: 0.01105 seconds
Time Taken: 0.00832 seconds
Time Before: 0.01349 seconds
Time After: 0.01387 seconds
Time Before: 0.01603 seconds
Time After: 0.01743 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01277 seconds
Time After: 0.01770 seconds
Time Taken: 0.00492 seconds
Time Before: 0.02284 seconds
Time After: 0.02306 seconds
Time Before: 0.02510 seconds
Time After: 0.02636 seconds
End call of global.php: 0.029269933700562
Time Before: 0.03040 seconds
Time After: 0.03052 seconds
Time Before: 0.03279 seconds
Time After: 0.03424 seconds
SET lastactivity = 1785352734, location = '/forums/private.php?do=newpm&explain=1&u=106847'
Time Before: 0.04799 seconds
Time After: 0.04819 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.047080039978027 seconds with 9 queries, spending 0.0085327625274658 doing MySQL queries and 0.038547277450562 doing PHP things.
