Time Before: 0.00169 seconds
Time After: 0.00224 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00231 seconds
Time After: 0.00276 seconds
Time Before: 0.00305 seconds
Time After: 0.00319 seconds
Time Before: 0.00410 seconds
Time After: 0.00676 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00327 seconds
Time After: 0.01144 seconds
Time Taken: 0.00816 seconds
Time Before: 0.01382 seconds
Time After: 0.01422 seconds
Time Before: 0.01657 seconds
Time After: 0.01776 seconds
Time Before: 0.01288 seconds
Time After: 0.01793 seconds
Time Taken: 0.00505 seconds
Time Before: 0.02285 seconds
Time After: 0.02300 seconds
Time Before: 0.02494 seconds
Time After: 0.02620 seconds
Time Before: 0.02911 seconds
Time After: 0.02926 seconds
Time Before: 0.03122 seconds
Time After: 0.03268 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106899', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05015 seconds
Time After: 0.05400 seconds
Time Taken: 0.00385 seconds
