Time Before: 0.00189 seconds
Time After: 0.00260 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00271 seconds
Time After: 0.00324 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00355 seconds
Time After: 0.00371 seconds
Time Before: 0.00457 seconds
Time After: 0.00733 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00379 seconds
Time After: 0.01140 seconds
Time Taken: 0.00762 seconds
Time Before: 0.01356 seconds
Time After: 0.01395 seconds
Time Before: 0.01667 seconds
Time After: 0.01794 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01287 seconds
Time After: 0.01812 seconds
Time Taken: 0.00525 seconds
Memory After: 2,261.820 KB
Time Before: 0.02452 seconds
Time After: 0.02474 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02747 seconds
Time After: 0.02874 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.030519008636475
Time Before: 0.03208 seconds
Time After: 0.03226 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03531 seconds
Time After: 0.03683 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788909864, location = '/forums/private.php?do=newpm&explain=1&u=106908'
Time Before: 0.05154 seconds
Time After: 0.05178 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.050637006759644 seconds with 9 queries, spending 0.0085582733154297 doing MySQL queries and 0.042078733444214 doing PHP things.
