Time Before: 0.02223 seconds
Time After: 0.03153 seconds
Time Taken: 0.00930 seconds
Time Before: 0.03165 seconds
Time After: 0.03247 seconds
Time Taken: 0.00082 seconds
Time Before: 0.03281 seconds
Time After: 0.03303 seconds
Time Before: 0.03383 seconds
Time After: 0.03596 seconds
Time Taken: 0.00214 seconds
Time Before: 0.03310 seconds
Time After: 0.04018 seconds
Time Taken: 0.00708 seconds
Time Before: 0.05035 seconds
Time After: 0.05073 seconds
Time Before: 0.05228 seconds
Time After: 0.05352 seconds
Time Before: 0.04962 seconds
Time After: 0.05373 seconds
Time Taken: 0.00410 seconds
Time Before: 0.08904 seconds
Time After: 0.08928 seconds
Time Before: 0.10784 seconds
Time After: 0.10942 seconds
Time Taken: 0.00159 seconds
End call of global.php: 0.1117160320282
Time Before: 0.12282 seconds
Time After: 0.12300 seconds
Time Before: 0.12565 seconds
Time After: 0.12713 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=106909'
Time Before: 0.14657 seconds
Time After: 0.14740 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.14520001411438 seconds with 9 queries, spending 0.0091011524200439 doing MySQL queries and 0.13609886169434 doing PHP things.
