Time Before: 0.01319 seconds
Time After: 0.01659 seconds
Time Taken: 0.00340 seconds
Time Before: 0.01669 seconds
Time After: 0.01714 seconds
Time Before: 0.01739 seconds
Time After: 0.01752 seconds
Time Before: 0.01840 seconds
Time After: 0.02111 seconds
Time Taken: 0.00270 seconds
Time Before: 0.01760 seconds
Time After: 0.02523 seconds
Time Taken: 0.00763 seconds
Time Before: 0.03034 seconds
Time After: 0.03074 seconds
Time Before: 0.03339 seconds
Time After: 0.03455 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02977 seconds
Time After: 0.03472 seconds
Time Taken: 0.00495 seconds
Time Before: 0.05486 seconds
Time After: 0.05501 seconds
Time Before: 0.06525 seconds
Time After: 0.06651 seconds
Time Before: 0.07417 seconds
Time After: 0.07434 seconds
Time Before: 0.07722 seconds
Time After: 0.07898 seconds
Time Taken: 0.00176 seconds
UPDATE session SET lastactivity = 1782955492, location = '/forums/private.php?do=newpm&explain=1&u=106932' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.09764 seconds
Time After: 0.09798 seconds
