Time Before: 0.00150 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00243 seconds
Time Before: 0.00260 seconds
Time After: 0.00275 seconds
Time Before: 0.00367 seconds
Time After: 0.00645 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00280 seconds
Time After: 0.01050 seconds
Time Taken: 0.00770 seconds
Time Before: 0.01218 seconds
Time After: 0.01253 seconds
Time Before: 0.01499 seconds
Time After: 0.01616 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01161 seconds
Time After: 0.01632 seconds
Time Taken: 0.00471 seconds
Time Before: 0.02121 seconds
Time After: 0.02163 seconds
Time Before: 0.02344 seconds
Time After: 0.02464 seconds
End call of global.php: 0.026281118392944
Time Before: 0.02775 seconds
Time After: 0.02793 seconds
Time Before: 0.02983 seconds
Time After: 0.03125 seconds
SET lastactivity = 1788884261, location = '/forums/private.php?do=newpm&explain=1&u=106951', badlocation = 1
Time Before: 0.04521 seconds
Time After: 0.04550 seconds
Page generated in 0.044336080551147 seconds with 9 queries, spending 0.0083620548248291 doing MySQL queries and 0.035974025726318 doing PHP things.
