Time Before: 0.02712 seconds
Time After: 0.03467 seconds
Time Taken: 0.00755 seconds
Time Before: 0.03479 seconds
Time After: 0.03547 seconds
Time Taken: 0.00068 seconds
Time Before: 0.03574 seconds
Time After: 0.03589 seconds
Time Before: 0.03673 seconds
Time After: 0.03902 seconds
Time Taken: 0.00229 seconds
Time Before: 0.03596 seconds
Time After: 0.04306 seconds
Time Taken: 0.00710 seconds
Time Before: 0.05324 seconds
Time After: 0.05365 seconds
Time Before: 0.05610 seconds
Time After: 0.05737 seconds
Time Before: 0.05254 seconds
Time After: 0.05762 seconds
Time Taken: 0.00508 seconds
Time Before: 0.10921 seconds
Time After: 0.10936 seconds
Time Before: 0.13192 seconds
Time After: 0.13330 seconds
Time Taken: 0.00138 seconds
Time Before: 0.14893 seconds
Time After: 0.14915 seconds
Time Before: 0.15260 seconds
Time After: 0.15410 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106954', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.17274 seconds
Time After: 0.17307 seconds
