Time Before: 0.00133 seconds
Time After: 0.00183 seconds
Time Before: 0.00192 seconds
Time After: 0.00251 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00277 seconds
Time After: 0.00292 seconds
Time Before: 0.00384 seconds
Time After: 0.00672 seconds
Time Taken: 0.00289 seconds
Time Before: 0.00300 seconds
Time After: 0.01014 seconds
Time Taken: 0.00714 seconds
Time Before: 0.01212 seconds
Time After: 0.01258 seconds
Time Before: 0.01580 seconds
Time After: 0.01701 seconds
Time Before: 0.01133 seconds
Time After: 0.01726 seconds
Time Taken: 0.00593 seconds
Time Before: 0.02355 seconds
Time After: 0.02375 seconds
Time Before: 0.02583 seconds
Time After: 0.02706 seconds
Time Before: 0.03042 seconds
Time After: 0.03057 seconds
Time Before: 0.03376 seconds
Time After: 0.03520 seconds
UPDATE session SET lastactivity = 1776464365, location = '/forums/private.php?do=newpm&explain=1&u=106962' WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.04934 seconds
Time After: 0.04965 seconds
