Time Before: 0.00139 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00241 seconds
Time Before: 0.00269 seconds
Time After: 0.00284 seconds
Time Before: 0.00368 seconds
Time After: 0.00664 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00292 seconds
Time After: 0.01160 seconds
Time Taken: 0.00868 seconds
Time Before: 0.01345 seconds
Time After: 0.01388 seconds
Time Before: 0.01652 seconds
Time After: 0.01776 seconds
Time Before: 0.01284 seconds
Time After: 0.01795 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02356 seconds
Time After: 0.02372 seconds
Time Before: 0.02572 seconds
Time After: 0.02706 seconds
Time Taken: 0.00133 seconds
Time Before: 0.03045 seconds
Time After: 0.03071 seconds
Time Before: 0.03285 seconds
Time After: 0.03465 seconds
Time Taken: 0.00180 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=106966' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04975 seconds
Time After: 0.05008 seconds
