Time Before: 0.00138 seconds
Time After: 0.00186 seconds
Time Before: 0.00193 seconds
Time After: 0.00230 seconds
Time Before: 0.00249 seconds
Time After: 0.00261 seconds
Time Before: 0.00341 seconds
Time After: 0.00617 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00266 seconds
Time After: 0.00958 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01129 seconds
Time After: 0.01147 seconds
Time Before: 0.01491 seconds
Time After: 0.01608 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01069 seconds
Time After: 0.01627 seconds
Time Taken: 0.00558 seconds
Time Before: 0.02114 seconds
Time After: 0.02129 seconds
Time Before: 0.02468 seconds
Time After: 0.02591 seconds
End call of global.php: 0.028402090072632
Time Before: 0.02974 seconds
Time After: 0.02991 seconds
Time Before: 0.03266 seconds
Time After: 0.03414 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107025', badlocation = 1
Time Before: 0.04823 seconds
Time After: 0.04860 seconds
Page generated in 0.047301054000854 seconds with 9 queries, spending 0.0080080032348633 doing MySQL queries and 0.039293050765991 doing PHP things.
