Time Before: 0.01921 seconds
Time After: 0.02270 seconds
Time Taken: 0.00349 seconds
Time Before: 0.02277 seconds
Time After: 0.02332 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02360 seconds
Time After: 0.02373 seconds
Time Before: 0.02446 seconds
Time After: 0.02729 seconds
Time Taken: 0.00283 seconds
Time Before: 0.02380 seconds
Time After: 0.03090 seconds
Time Taken: 0.00710 seconds
Time Before: 0.03633 seconds
Time After: 0.03673 seconds
Time Before: 0.03911 seconds
Time After: 0.04032 seconds
Time Before: 0.03569 seconds
Time After: 0.04050 seconds
Time Taken: 0.00481 seconds
Time Before: 0.07021 seconds
Time After: 0.07040 seconds
Time Before: 0.08077 seconds
Time After: 0.08207 seconds
Time Before: 0.09059 seconds
Time After: 0.09076 seconds
Time Before: 0.09369 seconds
Time After: 0.09518 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107072' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.11357 seconds
Time After: 0.11387 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
