Time Before: 0.02001 seconds
Time After: 0.02722 seconds
Time Taken: 0.00721 seconds
Time Before: 0.02731 seconds
Time After: 0.02771 seconds
Time Before: 0.02794 seconds
Time After: 0.02813 seconds
Time Before: 0.02891 seconds
Time After: 0.03210 seconds
Time Taken: 0.00319 seconds
Time Before: 0.02819 seconds
Time After: 0.03607 seconds
Time Taken: 0.00788 seconds
Time Before: 0.04334 seconds
Time After: 0.04373 seconds
Time Before: 0.04640 seconds
Time After: 0.04757 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04263 seconds
Time After: 0.04780 seconds
Time Taken: 0.00518 seconds
Time Before: 0.08228 seconds
Time After: 0.08246 seconds
Time Before: 0.09433 seconds
Time After: 0.09556 seconds
Time Before: 0.10668 seconds
Time After: 0.10695 seconds
Time Before: 0.11017 seconds
Time After: 0.11210 seconds
Time Taken: 0.00193 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107075', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.13086 seconds
Time After: 0.14279 seconds
Time Taken: 0.01193 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
