Time Before: 0.01360 seconds
Time After: 0.01808 seconds
Time Taken: 0.00448 seconds
Time Before: 0.01891 seconds
Time After: 0.01929 seconds
Time Before: 0.01952 seconds
Time After: 0.01969 seconds
Time Before: 0.02045 seconds
Time After: 0.02285 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01976 seconds
Time After: 0.02730 seconds
Time Taken: 0.00754 seconds
Time Before: 0.03328 seconds
Time After: 0.03393 seconds
Time Taken: 0.00065 seconds
Time Before: 0.03546 seconds
Time After: 0.03687 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03265 seconds
Time After: 0.03713 seconds
Memory After: 2,261.703 KB
Time Before: 0.06066 seconds
Time After: 0.06103 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07138 seconds
Time After: 0.07271 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.07964 seconds
Time After: 0.08010 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08342 seconds
Time After: 0.08485 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107077' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.09865 seconds
Time After: 0.09910 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
