Time Before: 0.00686 seconds
Time After: 0.00831 seconds
Time Before: 0.00841 seconds
Time After: 0.00887 seconds
Time Before: 0.00923 seconds
Time After: 0.00939 seconds
Time Before: 0.01024 seconds
Time After: 0.01308 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00946 seconds
Time After: 0.01771 seconds
Time Taken: 0.00825 seconds
Time Before: 0.02136 seconds
Time After: 0.02178 seconds
Time Before: 0.02458 seconds
Time After: 0.02604 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02047 seconds
Time After: 0.02632 seconds
Time Taken: 0.00585 seconds
Memory After: 2,261.820 KB
Time Before: 0.03856 seconds
Time After: 0.03871 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.04310 seconds
Time After: 0.04444 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.04957 seconds
Time After: 0.04973 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.05262 seconds
Time After: 0.05409 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789026020, location = '/forums/private.php?do=newpm&explain=1&u=107097', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.07349 seconds
Time After: 0.07377 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
