Time Before: 0.00149 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00255 seconds
Time Before: 0.00285 seconds
Time After: 0.00301 seconds
Time Before: 0.00389 seconds
Time After: 0.00659 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00308 seconds
Time After: 0.01107 seconds
Time Taken: 0.00799 seconds
Time Before: 0.01300 seconds
Time After: 0.01338 seconds
Time Before: 0.01594 seconds
Time After: 0.01724 seconds
Time Before: 0.01230 seconds
Time After: 0.01749 seconds
Time Taken: 0.00519 seconds
Time Before: 0.02285 seconds
Time After: 0.02302 seconds
Time Before: 0.02489 seconds
Time After: 0.02620 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.028180122375488
Time Before: 0.02962 seconds
Time After: 0.02983 seconds
Time Before: 0.03267 seconds
Time After: 0.03416 seconds
SET lastactivity = 1784821666, location = '/forums/private.php?do=newpm&explain=1&u=107115'
Time Before: 0.04823 seconds
Time After: 0.04854 seconds
Page generated in 0.04731297492981 seconds with 9 queries, spending 0.0085372924804688 doing MySQL queries and 0.038775682449341 doing PHP things.
