Time Before: 0.00152 seconds
Time After: 0.00207 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00214 seconds
Time After: 0.00247 seconds
Time Before: 0.00266 seconds
Time After: 0.00290 seconds
Time Before: 0.00352 seconds
Time After: 0.00579 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00294 seconds
Time After: 0.00923 seconds
Time Taken: 0.00629 seconds
Time Before: 0.01200 seconds
Time After: 0.01244 seconds
Time Before: 0.01505 seconds
Time After: 0.01627 seconds
Time Before: 0.01120 seconds
Time After: 0.01654 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02353 seconds
Time After: 0.02371 seconds
Time Before: 0.02595 seconds
Time After: 0.02725 seconds
Time Before: 0.03031 seconds
Time After: 0.03046 seconds
Time Before: 0.03258 seconds
Time After: 0.03419 seconds
Time Taken: 0.00161 seconds
UPDATE session SET lastactivity = 1782886608, location = '/forums/private.php?do=newpm&explain=1&u=107122', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04819 seconds
Time After: 0.04843 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
