Time Before: 0.01160 seconds
Time After: 0.01415 seconds
Time Taken: 0.00255 seconds
Time Before: 0.01424 seconds
Time After: 0.01467 seconds
Time Before: 0.01489 seconds
Time After: 0.01500 seconds
Time Before: 0.01569 seconds
Time After: 0.01783 seconds
Time Taken: 0.00214 seconds
Time Before: 0.01505 seconds
Time After: 0.02245 seconds
Time Taken: 0.00740 seconds
Time Before: 0.02801 seconds
Time After: 0.02838 seconds
Time Before: 0.03109 seconds
Time After: 0.03225 seconds
Time Taken: 0.00116 seconds
Time Before: 0.02725 seconds
Time After: 0.03243 seconds
Time Taken: 0.00517 seconds
Memory After: 2,885.227 KB
Memory Used: 132.898 KB
Time Before: 0.04920 seconds
Time After: 0.04933 seconds
Memory Before: 3,438.344 KB
Memory After: 3,438.859 KB
Time Before: 0.05814 seconds
Time After: 0.05936 seconds
Memory Before: 3,526.039 KB
Memory After: 3,526.633 KB
Time Before: 0.06457 seconds
Time After: 0.06472 seconds
Memory Before: 4,163.938 KB
Memory After: 4,164.367 KB
Time Before: 0.06696 seconds
Time After: 0.06841 seconds
Memory Before: 4,445.500 KB
Memory After: 4,447.188 KB
UPDATE session SET lastactivity = 1785356651, location = '/forums/private.php?do=newpm&explain=1&u=107138' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08570 seconds
Time After: 0.08607 seconds
Memory Before: 4,911.156 KB
Memory After: 4,911.383 KB
