Time Before: 0.02520 seconds
Time After: 0.03754 seconds
Time Taken: 0.01234 seconds
Time Before: 0.03765 seconds
Time After: 0.03805 seconds
Time Before: 0.03832 seconds
Time After: 0.03845 seconds
Time Before: 0.03942 seconds
Time After: 0.04187 seconds
Time Taken: 0.00245 seconds
Time Before: 0.03852 seconds
Time After: 0.04622 seconds
Time Taken: 0.00769 seconds
Time Before: 0.05428 seconds
Time After: 0.05471 seconds
Time Before: 0.05786 seconds
Time After: 0.05903 seconds
Time Taken: 0.00117 seconds
Time Before: 0.05362 seconds
Time After: 0.05923 seconds
Time Taken: 0.00561 seconds
Time Before: 0.09573 seconds
Time After: 0.09586 seconds
Time Before: 0.11744 seconds
Time After: 0.11867 seconds
Time Before: 0.13024 seconds
Time After: 0.13037 seconds
Time Before: 0.13286 seconds
Time After: 0.13431 seconds
UPDATE session SET lastactivity = 1777248715, location = '/forums/private.php?do=newpm&explain=1&u=107143', badlocation = 1 WHERE sessionhash = 'e9b85940693e8ec450606894f10508c2'
Time Before: 0.15233 seconds
Time After: 0.15257 seconds
