Time Before: 0.00138 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00233 seconds
Time Before: 0.00253 seconds
Time After: 0.00265 seconds
Time Before: 0.00338 seconds
Time After: 0.00543 seconds
Time Taken: 0.00206 seconds
Time Before: 0.00272 seconds
Time After: 0.00957 seconds
Time Taken: 0.00686 seconds
Time Before: 0.01154 seconds
Time After: 0.01191 seconds
Time Before: 0.01515 seconds
Time After: 0.01663 seconds
Time Before: 0.01088 seconds
Time After: 0.01681 seconds
Time Taken: 0.00593 seconds
Time Before: 0.02299 seconds
Time After: 0.02319 seconds
Time Before: 0.02522 seconds
Time After: 0.02648 seconds
End call of global.php: 0.028397083282471
Time Before: 0.02955 seconds
Time After: 0.02977 seconds
Time Before: 0.03288 seconds
Time After: 0.03437 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1784751709, location = '/forums/private.php?do=newpm&explain=1&u=107166', badlocation = 1
Time Before: 0.04878 seconds
Time After: 0.04905 seconds
Page generated in 0.047823905944824 seconds with 9 queries, spending 0.0078597068786621 doing MySQL queries and 0.039964199066162 doing PHP things.
