Time Before: 0.02225 seconds
Time After: 0.02889 seconds
Time Taken: 0.00665 seconds
Time Before: 0.02898 seconds
Time After: 0.02938 seconds
Time Before: 0.02962 seconds
Time After: 0.02974 seconds
Time Before: 0.03047 seconds
Time After: 0.03256 seconds
Time Taken: 0.00209 seconds
Time Before: 0.02980 seconds
Time After: 0.03644 seconds
Time Taken: 0.00664 seconds
Time Before: 0.04799 seconds
Time After: 0.04837 seconds
Time Before: 0.05015 seconds
Time After: 0.05132 seconds
Time Taken: 0.00116 seconds
Time Before: 0.04721 seconds
Time After: 0.05151 seconds
Time Taken: 0.00430 seconds
Time Before: 0.08589 seconds
Time After: 0.08605 seconds
Time Before: 0.10086 seconds
Time After: 0.10234 seconds
Time Before: 0.11536 seconds
Time After: 0.11578 seconds
Time Before: 0.11842 seconds
Time After: 0.11990 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107170', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.14023 seconds
Time After: 0.14049 seconds
