Time Before: 0.00170 seconds
Time After: 0.00219 seconds
Time Before: 0.00226 seconds
Time After: 0.00268 seconds
Time Before: 0.00287 seconds
Time After: 0.00304 seconds
Time Before: 0.00377 seconds
Time After: 0.00664 seconds
Time Taken: 0.00287 seconds
Time Before: 0.00309 seconds
Time After: 0.01002 seconds
Time Taken: 0.00693 seconds
Time Before: 0.01170 seconds
Time After: 0.01210 seconds
Time Before: 0.01498 seconds
Time After: 0.01625 seconds
Time Before: 0.01113 seconds
Time After: 0.01642 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02150 seconds
Time After: 0.02167 seconds
Time Before: 0.02364 seconds
Time After: 0.02485 seconds
End call of global.php: 0.026462078094482
Time Before: 0.02791 seconds
Time After: 0.02811 seconds
Time Before: 0.03023 seconds
Time After: 0.03165 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107199'
Time Before: 0.04391 seconds
Time After: 0.04434 seconds
Page generated in 0.043042182922363 seconds with 9 queries, spending 0.0085587501525879 doing MySQL queries and 0.034483432769775 doing PHP things.
