Time Before: 0.02513 seconds
Time After: 0.03376 seconds
Time Taken: 0.00863 seconds
Time Before: 0.03384 seconds
Time After: 0.03421 seconds
Time Before: 0.03447 seconds
Time After: 0.03463 seconds
Time Before: 0.03547 seconds
Time After: 0.03798 seconds
Time Taken: 0.00252 seconds
Time Before: 0.03471 seconds
Time After: 0.04222 seconds
Time Taken: 0.00750 seconds
Time Before: 0.05095 seconds
Time After: 0.05133 seconds
Time Before: 0.05400 seconds
Time After: 0.05527 seconds
Time Before: 0.05026 seconds
Time After: 0.05553 seconds
Time Taken: 0.00527 seconds
Time Before: 0.08596 seconds
Time After: 0.08612 seconds
Time Before: 0.10218 seconds
Time After: 0.10362 seconds
Time Before: 0.11695 seconds
Time After: 0.11712 seconds
Time Before: 0.12034 seconds
Time After: 0.12190 seconds
Time Taken: 0.00156 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107223', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.14171 seconds
Time After: 0.14200 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
