Time Before: 0.02667 seconds
Time After: 0.03322 seconds
Time Taken: 0.00655 seconds
Time Before: 0.03332 seconds
Time After: 0.03375 seconds
Time Before: 0.03417 seconds
Time After: 0.03460 seconds
Time Before: 0.03593 seconds
Time After: 0.03883 seconds
Time Taken: 0.00290 seconds
Time Before: 0.03467 seconds
Time After: 0.04367 seconds
Time Taken: 0.00900 seconds
Time Before: 0.05454 seconds
Time After: 0.05491 seconds
Time Before: 0.05674 seconds
Time After: 0.05811 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05391 seconds
Time After: 0.05836 seconds
Time Taken: 0.00445 seconds
Memory After: 2,261.820 KB
Time Before: 0.10237 seconds
Time After: 0.10302 seconds
Time Taken: 0.00064 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.12242 seconds
Time After: 0.12371 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.1262640953064
Time Before: 0.13552 seconds
Time After: 0.13568 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13957 seconds
Time After: 0.14116 seconds
Time Taken: 0.00159 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789089709, location = '/forums/private.php?do=newpm&explain=1&u=107244', badlocation = 1
Time Before: 0.16039 seconds
Time After: 0.16073 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.15943312644958 seconds with 9 queries, spending 0.009526252746582 doing MySQL queries and 0.149906873703 doing PHP things.
