Time Before: 0.00143 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00242 seconds
Time Before: 0.00262 seconds
Time After: 0.00275 seconds
Time Before: 0.00339 seconds
Time After: 0.00594 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00279 seconds
Time After: 0.00934 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01126 seconds
Time After: 0.01146 seconds
Time Before: 0.01391 seconds
Time After: 0.01516 seconds
Time Before: 0.01067 seconds
Time After: 0.01533 seconds
Time Taken: 0.00467 seconds
Time Before: 0.02037 seconds
Time After: 0.02057 seconds
Time Before: 0.02260 seconds
Time After: 0.02390 seconds
Time Before: 0.02664 seconds
Time After: 0.02692 seconds
Time Before: 0.02896 seconds
Time After: 0.03044 seconds
UPDATE session SET lastactivity = 1783235096, location = '/forums/private.php?do=newpm&explain=1&u=107253', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.04292 seconds
Time After: 0.04326 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
