Time Before: 0.00856 seconds
Time After: 0.01235 seconds
Time Taken: 0.00379 seconds
Time Before: 0.01248 seconds
Time After: 0.01304 seconds
Time Taken: 0.00057 seconds
Time Before: 0.01338 seconds
Time After: 0.01357 seconds
Time Before: 0.01436 seconds
Time After: 0.01730 seconds
Time Taken: 0.00294 seconds
Time Before: 0.01365 seconds
Time After: 0.02156 seconds
Time Taken: 0.00791 seconds
Time Before: 0.02526 seconds
Time After: 0.02568 seconds
Time Before: 0.02816 seconds
Time After: 0.02944 seconds
Time Before: 0.02454 seconds
Time After: 0.02967 seconds
Time Taken: 0.00513 seconds
Time Before: 0.04377 seconds
Time After: 0.04397 seconds
Time Before: 0.05056 seconds
Time After: 0.05180 seconds
End call of global.php: 0.053878784179688
Time Before: 0.05775 seconds
Time After: 0.05794 seconds
Time Before: 0.06129 seconds
Time After: 0.06389 seconds
Time Taken: 0.00260 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107285'
Time Before: 0.07947 seconds
Time After: 0.07971 seconds
Page generated in 0.078377962112427 seconds with 9 queries, spending 0.0098676681518555 doing MySQL queries and 0.068510293960571 doing PHP things.
