Time Before: 0.01006 seconds
Time After: 0.01566 seconds
Time Taken: 0.00559 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.01577 seconds
Time After: 0.01624 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.01643 seconds
Time After: 0.01662 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.01751 seconds
Time After: 0.02117 seconds
Time Taken: 0.00366 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.01668 seconds
Time After: 0.02642 seconds
Time Taken: 0.00974 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.03241 seconds
Time After: 0.03273 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.03511 seconds
Time After: 0.03632 seconds
Memory Before: 2,148.281 KB
Memory After: 2,148.141 KB
Time Before: 0.03175 seconds
Time After: 0.03658 seconds
Time Taken: 0.00483 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.164 KB
Time Before: 0.05869 seconds
Time After: 0.05883 seconds
Memory Before: 2,814.719 KB
Memory After: 2,815.234 KB
Time Before: 0.06898 seconds
Time After: 0.07024 seconds
Memory Before: 2,903.047 KB
Memory After: 2,903.641 KB
End call of global.php: 0.072397947311401
Time Before: 0.07664 seconds
Time After: 0.07683 seconds
Memory Before: 3,539.773 KB
Memory After: 3,540.203 KB
Time Before: 0.07936 seconds
Time After: 0.08083 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=107294'
Time Before: 0.09924 seconds
Time After: 0.09952 seconds
Memory Before: 4,294.930 KB
Memory After: 4,295.172 KB
Page generated in 0.098094940185547 seconds with 9 queries, spending 0.0091953277587891 doing MySQL queries and 0.088899612426758 doing PHP things.
