Time Before: 0.02565 seconds
Time After: 0.03179 seconds
Time Taken: 0.00614 seconds
Time Before: 0.03189 seconds
Time After: 0.03231 seconds
Time Before: 0.03257 seconds
Time After: 0.03277 seconds
Time Before: 0.03389 seconds
Time After: 0.03648 seconds
Time Taken: 0.00259 seconds
Time Before: 0.03289 seconds
Time After: 0.04210 seconds
Time Taken: 0.00921 seconds
Time Before: 0.05324 seconds
Time After: 0.05365 seconds
Time Before: 0.05607 seconds
Time After: 0.05730 seconds
Time Before: 0.05256 seconds
Time After: 0.05755 seconds
Time Taken: 0.00499 seconds
Time Before: 0.09016 seconds
Time After: 0.09041 seconds
Time Before: 0.10639 seconds
Time After: 0.10764 seconds
End call of global.php: 0.10985708236694
Time Before: 0.12652 seconds
Time After: 0.12670 seconds
Time Before: 0.12947 seconds
Time After: 0.13091 seconds
SET lastactivity = 1784786449, location = '/forums/private.php?do=newpm&explain=1&u=107303', badlocation = 1
Time Before: 0.15155 seconds
Time After: 0.15195 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.15041208267212 seconds with 9 queries, spending 0.008354663848877 doing MySQL queries and 0.14205741882324 doing PHP things.
