Time Before: 0.00225 seconds
Time After: 0.00299 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00309 seconds
Time After: 0.00351 seconds
Time Before: 0.00375 seconds
Time After: 0.00388 seconds
Time Before: 0.00480 seconds
Time After: 0.00828 seconds
Time Taken: 0.00348 seconds
Time Before: 0.00395 seconds
Time After: 0.01425 seconds
Time Taken: 0.01029 seconds
Time Before: 0.01667 seconds
Time After: 0.01702 seconds
Time Before: 0.01961 seconds
Time After: 0.02077 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01591 seconds
Time After: 0.02102 seconds
Time Taken: 0.00511 seconds
Memory After: 2,261.703 KB
Time Before: 0.02842 seconds
Time After: 0.02859 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.03138 seconds
Time After: 0.03268 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.035521030426025
Time Before: 0.03701 seconds
Time After: 0.03715 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.04018 seconds
Time After: 0.04166 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=107313'
Time Before: 0.06157 seconds
Time After: 0.06184 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.060195922851562 seconds with 9 queries, spending 0.0089118480682373 doing MySQL queries and 0.051284074783325 doing PHP things.
