Time Before: 0.00196 seconds
Time After: 0.00257 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00268 seconds
Time After: 0.00311 seconds
Time Before: 0.00330 seconds
Time After: 0.00345 seconds
Time Before: 0.00412 seconds
Time After: 0.00629 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00350 seconds
Time After: 0.01105 seconds
Time Taken: 0.00755 seconds
Time Before: 0.01284 seconds
Time After: 0.01320 seconds
Time Before: 0.01569 seconds
Time After: 0.01683 seconds
Time Taken: 0.00114 seconds
Time Before: 0.01228 seconds
Time After: 0.01703 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02256 seconds
Time After: 0.02281 seconds
Time Before: 0.02500 seconds
Time After: 0.02625 seconds
End call of global.php: 0.028151988983154
Time Before: 0.02943 seconds
Time After: 0.02960 seconds
Time Before: 0.03177 seconds
Time After: 0.03320 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107321', badlocation = 1
Time Before: 0.04674 seconds
Time After: 0.04708 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.045732021331787 seconds with 9 queries, spending 0.0077133178710938 doing MySQL queries and 0.038018703460693 doing PHP things.
