Time Before: 0.00154 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00247 seconds
Time Before: 0.00272 seconds
Time After: 0.00285 seconds
Time Before: 0.00364 seconds
Time After: 0.00642 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00293 seconds
Time After: 0.01180 seconds
Time Taken: 0.00887 seconds
Time Before: 0.01470 seconds
Time After: 0.01512 seconds
Time Before: 0.01777 seconds
Time After: 0.01897 seconds
Time Before: 0.01392 seconds
Time After: 0.01924 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02625 seconds
Time After: 0.02656 seconds
Time Before: 0.02885 seconds
Time After: 0.03016 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.032856941223145
Time Before: 0.03463 seconds
Time After: 0.03508 seconds
Time Before: 0.03842 seconds
Time After: 0.04000 seconds
Time Taken: 0.00158 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107356'
Time Before: 0.05426 seconds
Time After: 0.05550 seconds
Page generated in 0.053340911865234 seconds with 9 queries, spending 0.0098464488983154 doing MySQL queries and 0.043494462966919 doing PHP things.
