Time Before: 0.00577 seconds
Time After: 0.00753 seconds
Time Taken: 0.00175 seconds
Time Before: 0.00762 seconds
Time After: 0.00811 seconds
Time Before: 0.00839 seconds
Time After: 0.00860 seconds
Time Before: 0.00929 seconds
Time After: 0.01190 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00866 seconds
Time After: 0.01617 seconds
Time Taken: 0.00750 seconds
Time Before: 0.01976 seconds
Time After: 0.02022 seconds
Time Before: 0.02152 seconds
Time After: 0.02272 seconds
Time Before: 0.01878 seconds
Time After: 0.02292 seconds
Time Taken: 0.00415 seconds
Time Before: 0.04010 seconds
Time After: 0.04024 seconds
Time Before: 0.04679 seconds
Time After: 0.04807 seconds
End call of global.php: 0.050237894058228
Time Before: 0.05311 seconds
Time After: 0.05329 seconds
Time Before: 0.05528 seconds
Time After: 0.05674 seconds
SET lastactivity = 1776699618, location = '/forums/private.php?do=newpm&explain=1&u=107391'
Time Before: 0.07219 seconds
Time After: 0.07295 seconds
Time Taken: 0.00075 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.071278810501099 seconds with 9 queries, spending 0.0087900161743164 doing MySQL queries and 0.062488794326782 doing PHP things.
