Time Before: 0.00141 seconds
Time After: 0.00187 seconds
Time Before: 0.00195 seconds
Time After: 0.00258 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00286 seconds
Time After: 0.00313 seconds
Time Before: 0.00381 seconds
Time After: 0.00646 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00318 seconds
Time After: 0.01203 seconds
Time Taken: 0.00885 seconds
Time Before: 0.01476 seconds
Time After: 0.01532 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01805 seconds
Time After: 0.01982 seconds
Time Taken: 0.00177 seconds
Time Before: 0.01381 seconds
Time After: 0.02012 seconds
Time Taken: 0.00631 seconds
Time Before: 0.02749 seconds
Time After: 0.02763 seconds
Time Before: 0.02963 seconds
Time After: 0.03093 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03489 seconds
Time After: 0.03512 seconds
Time Before: 0.03759 seconds
Time After: 0.03905 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107392', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.05159 seconds
Time After: 0.05187 seconds
