Time Before: 0.00780 seconds
Time After: 0.00956 seconds
Time Taken: 0.00176 seconds
Time Before: 0.00966 seconds
Time After: 0.01014 seconds
Time Before: 0.01037 seconds
Time After: 0.01050 seconds
Time Before: 0.01123 seconds
Time After: 0.01386 seconds
Time Taken: 0.00263 seconds
Time Before: 0.01057 seconds
Time After: 0.01787 seconds
Time Taken: 0.00730 seconds
Time Before: 0.02085 seconds
Time After: 0.02126 seconds
Time Before: 0.02371 seconds
Time After: 0.02494 seconds
Time Before: 0.02014 seconds
Time After: 0.02515 seconds
Time Taken: 0.00500 seconds
Time Before: 0.03865 seconds
Time After: 0.03879 seconds
Time Before: 0.04510 seconds
Time After: 0.04642 seconds
Time Taken: 0.00132 seconds
Time Before: 0.05322 seconds
Time After: 0.05337 seconds
Time Before: 0.05574 seconds
Time After: 0.05731 seconds
Time Taken: 0.00157 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107412' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.07347 seconds
Time After: 0.07382 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
