Time Before: 0.02240 seconds
Time After: 0.03342 seconds
Time Taken: 0.01101 seconds
Time Before: 0.03353 seconds
Time After: 0.03401 seconds
Time Before: 0.03431 seconds
Time After: 0.03447 seconds
Time Before: 0.03527 seconds
Time After: 0.03722 seconds
Time Taken: 0.00195 seconds
Time Before: 0.03454 seconds
Time After: 0.04143 seconds
Time Taken: 0.00688 seconds
Time Before: 0.05132 seconds
Time After: 0.05171 seconds
Time Before: 0.05445 seconds
Time After: 0.05572 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05060 seconds
Time After: 0.05602 seconds
Time Taken: 0.00542 seconds
Memory After: 2,261.703 KB
Time Before: 0.09347 seconds
Time After: 0.09359 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11524 seconds
Time After: 0.11650 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.13274 seconds
Time After: 0.13292 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.13611 seconds
Time After: 0.13759 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107434' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15653 seconds
Time After: 0.15678 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
