Time Before: 0.00142 seconds
Time After: 0.00202 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00209 seconds
Time After: 0.00248 seconds
Time Before: 0.00270 seconds
Time After: 0.00283 seconds
Time Before: 0.00355 seconds
Time After: 0.00608 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00287 seconds
Time After: 0.00977 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01152 seconds
Time After: 0.01192 seconds
Time Before: 0.01437 seconds
Time After: 0.01559 seconds
Time Before: 0.01097 seconds
Time After: 0.01577 seconds
Time Taken: 0.00480 seconds
Time Before: 0.02205 seconds
Time After: 0.02223 seconds
Time Before: 0.02448 seconds
Time After: 0.02577 seconds
Time Before: 0.02880 seconds
Time After: 0.02897 seconds
Time Before: 0.03157 seconds
Time After: 0.03301 seconds
UPDATE session SET lastactivity = 1789115625, location = '/forums/private.php?do=newpm&explain=1&u=107437' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04721 seconds
Time After: 0.04781 seconds
