Time Before: 0.00163 seconds
Time After: 0.00224 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00230 seconds
Time After: 0.00286 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00306 seconds
Time After: 0.00319 seconds
Time Before: 0.00386 seconds
Time After: 0.00605 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00324 seconds
Time After: 0.00943 seconds
Time Taken: 0.00619 seconds
Time Before: 0.01150 seconds
Time After: 0.01174 seconds
Time Before: 0.01427 seconds
Time After: 0.01545 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01087 seconds
Time After: 0.01564 seconds
Time Taken: 0.00477 seconds
Time Before: 0.02073 seconds
Time After: 0.02089 seconds
Time Before: 0.02301 seconds
Time After: 0.02425 seconds
Time Before: 0.02858 seconds
Time After: 0.02879 seconds
Time Before: 0.03173 seconds
Time After: 0.03322 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107456', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.04998 seconds
Time After: 0.05025 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
