Time Before: 0.00202 seconds
Time After: 0.00271 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00280 seconds
Time After: 0.00326 seconds
Time Before: 0.00355 seconds
Time After: 0.00369 seconds
Time Before: 0.00463 seconds
Time After: 0.00838 seconds
Time Taken: 0.00375 seconds
Time Before: 0.00377 seconds
Time After: 0.01198 seconds
Time Taken: 0.00821 seconds
Time Before: 0.01382 seconds
Time After: 0.01403 seconds
Time Before: 0.01645 seconds
Time After: 0.01792 seconds
Time Before: 0.01321 seconds
Time After: 0.01820 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02471 seconds
Time After: 0.02490 seconds
Time Before: 0.02675 seconds
Time After: 0.02799 seconds
End call of global.php: 0.030755043029785
Time Before: 0.03219 seconds
Time After: 0.03245 seconds
Time Before: 0.03535 seconds
Time After: 0.03681 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107472'
Time Before: 0.05193 seconds
Time After: 0.05225 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
Page generated in 0.051014184951782 seconds with 9 queries, spending 0.0095045566558838 doing MySQL queries and 0.041509628295898 doing PHP things.
